i mentioned it in discord but making a thread there to track it.
it would be great if the vban receptor & talkie apps on iOS would capture the system play/pause and volume commands and send them back as midi commands that can then be used to control media playing on the computer.
this would let you use any headset with controls (wired or wireless) to control media playing on a computer that may not be able to interpret the controls properly.
