Using VB-Cable with OBS to stream Audio from video to Zoom
mdmalamud
Contact:
Post by mdmalamud »
I have followed the YouTube https://www.youtube.com/watch?v=ad30G5oBHtg&t=14s with no success. I have tried to create monitors as a filter to the video media player. I have tried separate sourse in same scene as video media player. I have gotten it to work with LoopBack and I am looking for a cheaper answer. :?: :?: :?: :?:
MDMalamud
Re: Using VB-Cable with OBS to stream Audio from video to Zoom
VB-CABLE is a simple virtual audio cable to connect 2x applications together (a player to a recorder).
Since you have basically 2 capture applications (OBS and ZOOM) you must consider using Voicemeeter Banana.
watch this video to start your config: https://youtu.be/nIpt3jF0Nds
mdmalamud
Contact:
Post by mdmalamud »
Did you miss that I am on a Mac?????
yes, sorry... on MAC, you may come on our Discord server to find someone to help you so.
