Voicemeeter is able to manage 2x output devices in the same time!
You just have to select them as output A1 and output A2!
STEP -1- prerequisite: you must have an audio source entering in Voicemeeter.
This can be your microphone or this can be your PC Sound coming in Voicemeeter Virtual Input set as default playback device.
STEP -2- Select your first output Device as output A1
Just click on A1 button to open the device selector.
STEP -3- Select your first output Device as output A2
Just click on A2 button to open again the device selector.
Then all sources sent to BUS A is playing back in both devices selected as A1 and A2.
However you have a single slider gain for both device. In other words, both output devices are connected to the same output BUS.
With Voicemeeter Banana version, output A1 and output A2 have their own BUS , so you can control output A1 and A2 device, source assignation and gain, independently. Note you must assign your source to A1 and A2 on Voicemeeter Banana to send the sound to both device A1 and A2.
How to playback in 2x Output Devices in the same time (3 Steps)
