Page 2 of 2
Re: Voicemeeter will not open up at all (HDMI / Display port)
Posted: Mon Jan 03, 2022 1:14 am
by digitalsushi
I wanted to add to this as I'm currently having the same problem. My new laptop has a 11th gen i7-1195G7. The common thread here seems to be the 11th gen integrated Intel Iris Xe GPU's HD Audio Driver. I've updated and even tried rolling back to older versions but all of the HD Audio drivers seem to crash Voicemeeter/banana/potato as soon as I plug in an HDMI to my laptop. (And it won't reopen unless I unplug the HDMI)
My older model of the exact laptop is using intel's 10th gen integrated GPU and it works fine but is named "Intel Display Driver" instead going through the same process. But my work needs the new Iris Xe GPU as it's a lot more powerful/efficient.
I can't really uninstall/disable the driver as I do need to send audio to my hdmi through voicemeeter's output.
Is there anything I can post to help find a proper fix for the issue?
Much appreciated.
Posted: Wed Jan 05, 2022 8:48 am
thanks for reporting.
we will correct this problem on our side, when we will have a PC/config reproducing it...
will going to buy a PC with Intel Iris XE inside...
Posted: Sat Jan 08, 2022 2:08 pm
Got a PC intel with IRIS XE Chipset and found the problem. I'm going to try to plan a Voicemeeter update before end of January (Will be fixed in version 3.02.2 / 2.0.6.2 / 1.0.8.2).
I Just updated the DeviceChecker program (version 1.0.8.2) that now should work... if you want to test:
https://download.vb-audio.com/Download_ ... eCheck.zip
