Page 2 of 2
Re: Audio Choppy when using Virtual Cables
Posted: Tue Oct 19, 2021 2:31 am
by V1perN3st
I didn't really think of that (kind of forgot there are other interfaces). So in my testing, it seems the issue is only with WDM. KS and MME all seemed fine. I read the manual, but I am not sure which is the best one to us (WDM is out at this point as I have the issue with it). MME seems to be an old standard and KS isn't compatible with everything. KS seems to work just fine so I will go with that and see how it works for me (unless it would be recommended to use MME over KS).
I didn't know there was an updated version out as well. I will say it is a bit of a pain to upgrade VoiceMeeter (it tends to break the Virtual Cables and I end up having to reinstall them as well). Looking at the download page, I only see the 3.0.1.8 version (which is what I am running). I am guessing the 3.0.2.0 is in beta or pre-release?
Posted: Sat Oct 23, 2021 9:13 am
yes, 3.0.2.0 is the pre-release version, we plan a last update in the next week or just after.
