when I use Fn keys on laptop or volume knob on a keyboard the volume bar changes but the actual volume dont. It only turn off when the bar is at the bottom.
Is this a feature or I'm missing something?
I have all cables, A to D and they works perfectly, except the volume problem.
Thanks,
S@
Volume not changing on VB-CABLE
Re: Volume not changing on VB-CABLE
there is no windows volume control in our virtual cable.
skullmonkey
Too bad. Would have been perfect solution.Vincent Burel wrote:there is no windows volume control in our virtual cable.
Anyway,
thanks.
it's a cable, there is no gain control in a cable...
if you need such Control, use Voicemeeter with...
