Hi guys, i ve been struggling with an issue that doesn t seem to get any better.... in my Virtual input you can read "no drivers present". I believe this is the main problem cause i can t send my Cubase signal........ can u help me ?? thnks !!
greetings
juan
Virtual input - no drivers present
Re: Virtual input - no drivers present
Hi. When you install Voicemeeter, it also installs an audio driver for a virtual device; depending on the version of Voicemeeter, your installation includes one or multiple virtual audio input/output devices, known as VB-Audio VoiceMeeter VAIO. Apparently there is a problem with the installation of this audio driver. You should first check your installation by using Device Manager. See this topic: viewtopic.php?p=2102
There are two types of devices to check:
- Sound, video and game controllers: Look for VB-Audio VoiceMeeter VAIO and VB-Audio VoiceMeeter Aux VAIO (if using Voicemeeter Banana)
- Audio inputs and outputs: There should be one input and one output for each VAIO device.
thanks!!! i ll try that .... i ll be in touch
