I have auto ducking enabled on strip 7 which is where I have spotify routed to, but my mic is being sent to discord through voicemeeter, via strip 0, and my stream mic is it's own separate input on OBS, is there a way to set up a keybind to disable auto ducking when I need to? That way I can just use Touch Portal buttons to control my volume after I've done my introduction segment on stream, and still be able to have music in the background while being able to talk in discord without the auto ducking kicking in.
Hope this makes sense lol.
Disable Auto Ducking with a keybind.
Re: Disable Auto Ducking with a keybind.
next version will include an instruction for MacroButtons:
Button(n).Trigger = 0/1 instruction allows to enable / disable the audio trigger process on a given button.
