hi
i am working on a new midi controller using a teensy 4.1. i have noticed that voicemeeter is losing its connection with it when the computer goes to sleep and not reconnecting when it wakes up.
initially i thought it was the teensy or my code however i have tested with MIDI-OX and it maintains a constant signal the whole time.
im not sure how well this could be tested as it is inconsistent and may be hardware dependant. i think it has something to do with the feedback system. when i turn off all the feedback it stops disconnecting. unfortunately the catalyst for this project was the addition feedback as it is centered around a powered fader.
im not sure what other info i should add but let me know if you need more.
MIDI not reconnecting when waking from sleep
TomW1605
Re: MIDI not reconnecting when waking from sleep
you may make a RESTART AUDIO ENGINE (in Voicemeeter Menu), no ?
TomW1605
hi
unfortunately the problem has decided to hide this afternoon so i can't reproduce it right now to test but i did try using the "restart audio engine" option before and it did not work. i also have the auto restart enabled but i don't think that would detect it anyway
TomW1605
ok it happened again but this time restarting the audio engine worked. unfortunately the point of the project is to not have to open the app as often as i do so having to open it after waking up somewhat defeats the purpose. are there any log files i can send you that might help you track down the issue?
