VB-Cable Install Issue
Posted: Fri Aug 20, 2021 6:41 pm
by N1GAW
I'm currently using A-B cable and it works great for me. Wanted to add in the C-D cable to add an additional SDR for UT2 and Trunking Recorder, but when I added it all cables stopped working and no audio was being sent.
Any trouble shooting suggestions?
Re: VB-Cable Install Issue
Posted: Mon Aug 23, 2021 11:57 am
Hi. You could start checking VB-Audio Virtual Cable installation using the utility mentioned in this post:
You can also try to get help using VB-Audio Discord Server. You will find the link in the VB-Audio Support page:
https://vb-audio.com/Services/support.htm
Hope this helps.
