Voicemeeter and UMC204HD audio artifacts
Posted: Tue Nov 09, 2021 11:45 pm
Hi
I had a working VMpotato setup on Win10 using my Behringer UMC204HD as the output.
I recently have had to upgrade to Win11 and since then there have been audio problems when routing my audio through VM.
If I tell windows to output directly to the soundcard it sounds as it should, but when directing the audio via voicemeeter aux it sounds distorted and 'crunchy'.
I have tried reinstalling VM and the UMC audio drivers but the problem remains.
Any ideas of what I can try?
Thanks.
Thanks.
