VoiceMeeter showing deactive device
dermaxem
Post by dermaxem »
hi there,
if i like to select a device for hardware-output, the devicelist is filled with deactive device.
why?
in the windows-sound-settigs the deactive device are not shown. and theres a switch to turn them on or off.
Re: VoiceMeeter showing deactive device
apparently it's only the KS Interfaces that does not take in account the Disable status of your device.
i note it for the next update... or next after, because apparently, to know if a audio device is disabled is a problem for KS interface...
