Voicemeeter Banana is offering the same built FX than Voicemeeter Standard but adds a new panel for modulation fx and provide the INTELLIGIBILITY knob as two separate knobs: one for the compressor and one for the gate. Please read first the guide about Voicemeeter Standard: viewtopic.php?t=2044
Step -1- Boost your voice with the compressor knob
Comp knob is controlling the compressor with auto make up. It means the compression is compensated by a gain to keep original level but boosted. Usual values are around 2 or 3.0.
If it's too loud, simply use the slider gain below to decrease the gain (and possibly remove AUTO MAKE UP effect).
Step -2- Tweak the Gate Knob
With Banana the gate and compressor are independent. The gate is made to mute low level sound (like noise) and let bigger sound (like your voice) go on air. Adjust the gate knob to get your voice without cut. Usual value is around 2.0 . Above 5.0 the the gate is made for noisy environments when you have to talk very loud in your microphone (clubbing, public event...).
Step -3- Use the Modulation panel to make strange voice
Right click on 2D PANEL to change it to MODULATION one. The MODULATION PANEL is a special fx to make strange voice like Dark Vador, Decepticon and many other Robots etc... This is presented as a grid where you can find a different FX in each cell and cross. Just move the cursor slowly to adjust the FX you want to get (phaser, chorus and other modulations).
Double click to reset FX to neutral position.
How to improve your mic with Voicemeeter Banana (3 Steps)
