Can Voicemeeter Help with Complex Setup?
Posted: Sun Aug 26, 2018 9:08 am
Abbreviations:
REASON = A well known DAW
ExtS = Physical External Soundcard - there are two of them, #1 & #2
MULTITRACK = Multitrack Recorder DAW
Ch. = Channel
BORING DAW = just a different DAW
THE SETUP :
[NOTE: ExtS #1 is a general use device with 4 stereo I/O channels selectable by computer-->USB (ASIO), or by phono lead]
[NOTE: ExtS #2 Ch.3/4 is a sort of universal cue channel, it is listened to via one pair of physical headphones]
REASONs main output rack channels --> [using ASIO4ALL] --> MULTITRACK Instance #1 (1 MULTITRACK channel per Reason rack device) --> [using ASIO4ALL] --> ExtS #1 Ch.1/2
REASON's cue track --> [using ASIO4ALL] --> MULTITRACK Instance #1 --> [using ASIO4ALL] --> ExtS #2 Ch.3/4 --> Physical headphones
BORING DAW Instance #1 --> [using ASIO4ALL] --> MULTITRACK Instance #2 --> [using ASIO4ALL] --> ExtS #1 Ch.7/8
BORING DAW Instance #2 Main Out --> [using ExtS #2's own ASIO driver] --> ExtS #2 Ch.1/2 --> [using physical wire] --> ExtS #1 (can hear it by flipping USB / Phono switch, thus toggling between the Reason rack channels & BORING DAW Instance #2 Main Out)
BORING DAW Instance #2 Cue Channel --> [using ExtS #2's own ASIO driver] --> ExtS #2 Ch.3/4 --> Physical headphones
My problem:
This setup is very crashy & jittery when play is pressed in one DAW rather than another DAW.
I ABSOLUTELY NEED to hear audio from another DAW in ExtS #1 Ch.3/4 + Ch.5/6. This audio needs to come from ANOTHER DAW NOT MENTIONED HERE. This is the biggest problem for me - ExtS #1 is already in use (heavy use, at that) by MULTITRACK Instance #1 *and* Instance #2. Therefore l cannot use ASIO.
Can Voicemeeter help? If so, please could you give me a clear idea of how to proceed? Please could you explain like you are trying to teach a cat!
Also, if you need further clarification on something, please ask.
Ch. = Channel
THE SETUP :
My problem:
