How to improve your mic with Voicemeeter Potato (6 Steps)
All Guides to explain how to do everything with Voicemeeter...
Locked
Voicemeeter Potato is offering the same built-in FX than Voicemeeter Banana and adds a 6 bands parametric EQ on stereo input strips, gives access to compressor and gate detailed parameters, offers a denoiser and voice modeler effect and features two special FX as AUX FX (Reverb, Delay). Please read first the guide about Voicemeeter Banana: ⁠viewtopic.php?t=2045
Step -1- Use parametric EQ on input strip
The small EQ button allows to switch ON/OFF the 6 bands parametric EQ (Left Click). Right Click to open the Graphic User Interface.
Typical use of a parametric EQ for voice is to use LPF filter to remove low frequencies (pop and sub bass), possibly boost or remove some part of the voice sound (200 - 5000 Hz) and manage the treble amount (> 5000 Hz). Here we just add some clarity by adding 6 dB around 2 KHz and remove treble.
Step -2- Manage compressor
You can use the Compressor knob like in Voicemeeter Banana or use detailed parameters for better control of the effect (right click on Knob to display them).
- Input Gain: To control the gain before compression.
- Ratio: Gives the compression rate.
- Threshold: Define a level to start the compression when the input signal goes over this threshold.
- Attack Time: to control the compression behavior on sound attack (when the input signal starts to go over the threshold).
- Release Time: to control the compression behavior when the signal goes down.
- Knee: To control the compression transition softness on threshold point.
- Output Gain: To control the gain after compression.
- Auto make Up: apply an output gain automatically computed to compensate the compression.
Step -3- Manage Gate
You can use the Gate knob like in Voicemeeter Banana or use detailed parameters for better control of the effect (right click on Knob to display them).
- Threshold: If input gain is below this level the gate is closing, above this level the gate is opening.
- Damping Max: Allows limiting the gain reduction when the gate is closing. Per default OFF = -inf, the gate completely remove the signal when closing.
- BP Sidechain: This parameters allows to define a Band Pass frequency (1,5 octave) in the sidechain (input signal controlling the gate). Then the gate will react on specific frequency range only.
- Attack time: Define how long it takes to open the gate (gain increasing time).
- Hold Time: Define the minimal time the gate stays opened anyway (whatever the input gain).
- Release Time: Define how long it takes to close the gate (gain decreasing time).
Step -4- Use the Denoiser to remove background noise
if you use a low quality microphone or talk too far from your mic, you may have a big amount of background noise and the Potato Denoiser Fx is perfect to remove it. Just turn the knob to 5.0 and wait 10 seconds, the noise floor should be removed.
Step -5- Change your voice with the Voice Modeler
The Potato Voice Modeler allows to turn your voice in another one, lower or higher, more or less natural (pending on formant tweaking).
- Enable Fx: Activate the Voice Modeler effect.
- Dry / Wet Balance: gives the amount of dry signal (original input = -100%) and wet signal (Fx = +100%). 0% mean same amount for dry and wet signal.
- Pitch: pitch amount in semi tone (from -12 to +12 semi tone).
- Formant Lo: Pitch for low frequency formant (from -12 to +12 semi tone).
- Formant Med: Pitch for medium frequency formant (from -12 to +12 semi tone).
- Formant Hi: Pitch for high frequency formant (from -12 to +12 semi tone).
- Formant Group: 3 Formant average control, to change all formant in the same time (relatively).
Step -6- Use built-in Special AUX Fx (Reverb, delay)
Potato version offers built in special FX like Reverb and Delay as auxiliary effect. In a mixing console, an AUX FX is a like an external Fx unit, but built in the console. The source is sent to the AUX FX input by a Send Knob, the output of the FX is managed by a return knob.
This the exact purpose of the SPECIAL FX knob present on all stereo input strips: to send your mic to a Reverb and/or a Delay FX, typically to add reverb or delay on your voice.
To listen to your added Reverb or Delay Fx, you have to use the Return knob provided on each output BUS. the output of each effect is added to the BUS to let you manage the exact amount of Fx you want to hear at the end.
This way to add AUX FX is particularly adapted to special Fx expected to be added to the original source signal. Then you can add Reverb or Delay FX to several sources if you want (all stereo input strip can be sent to AUX FX).
Locked
